TwinTurbo.NET: Nissan 300ZX forum - Usualy higher the pressure the less the flow because
Subject Usualy higher the pressure the less the flow because
Posted by AzHeat on October 04, 2006 at 5:57 PM
  This message has been viewed 308 times.
In Reply To FLOWBENCH Extravaganza: MAS Voltage to CFM Chart posted by Ash's Z on October 04, 2006 at 05:16 PM
Message pressure is a measure directly related to resistance. An engine with big cams and ported heads and free flowing exhaust will flow more air at the same boost pressure as a stock engine. If I have a kink in the straw my flow will be zero and pressure will be higher. Just like you can have swamp cooler fan flow 4000 cfm but the pressure is low.
